5th Gen ('95-'99): Anybody know where to find dome light circuit?
Old Mar 26, 2013 | 08:30 PM
98MonteCarloZ34's Avatar
Default Anybody know where to find dome light circuit?
I am looking to install these LED Projectors. I want to find the dome light circuit. I cannot seem to find it? Can somebody hellp me out here?
Old Mar 26, 2013 | 08:40 PM
nitehawkjcb's Avatar
Are you putting them in the dome light?
Old Mar 26, 2013 | 09:28 PM
I've seen those, my step dad has a set for his Fiero. Those are sweet. I would love to see a company could do the Monte knight's crest!
Old Mar 27, 2013 | 06:56 PM
No, I want them wire to the circuit so when the door opens the projectors turn on when the dome light does.
Old Mar 27, 2013 | 07:07 PM
zzapultimate's Avatar
I believe you can find it in the kick panel. I forget on the exact color of the wire. I've tapped into it more than once before. I could look at my car and see if I can find where I tapped into it.
Old Mar 27, 2013 | 07:13 PM
tps221's Avatar
could just tap the wire at the dome light
Old Mar 27, 2013 | 08:55 PM
You could, but I believe these projectors are installed in the bottom of the door. That would be a long ways to run the wire if you tapped into the dome light. Plus, you'd have to take apart all of the trim around the headliner to run the wire. I would think tapping into the circuit at the kick panel which is closest to door where the wire would be run would be the simplest.
Old Mar 28, 2013 | 08:23 PM
If you could do that, it would be great! Thanks!
Old Mar 28, 2013 | 10:56 PM
I'll check this weekend. I'm planning on doing some work to it and cleaning it up so I can let you know
Old Mar 31, 2013 | 05:40 PM
Thank you so much!
reaper18769
Sep 5, 2010 10:34 PM
wht02monte
Jul 19, 2010 11:04 PM
Dave McFly
Jun 12, 2010 01:22 AM
ComradeRedXv2
Oct 17, 2009 04:18 PM
TrapShooter8
Apr 4, 2007 10:26 PM
