air intake=gauge probs
Old Mar 21, 2008 | 10:25 PM
SilentWutch's Avatar
Default air intake=gauge probs
ever since i put a k&N intake in ive had probs w/ all my gauges( but sped. and battery) and warning lights. HELP!
Old Mar 21, 2008 | 10:37 PM
scc24540's Avatar
Default RE: air intake=gauge probs
ORIGINAL: SilentWutch
what car do you have, what engine, and did you unhook anything while doing the install?
Old Mar 21, 2008 | 11:18 PM
i got an 03 SS 3800. i had to unplug the pcm and mount it 2 the heat shield
Old Mar 21, 2008 | 11:29 PM
mickey's Avatar
I have one in mine and never even had a glitch with my guage pod.
try installing the air box again and see if it stops this but i have a feeling it is more a fluke tha tthey happend at the same time.
if you unhooked the computer you might also try a re learn on it unhook the bat. and walk away for about a hour or so and try agian.
Old Mar 21, 2008 | 11:44 PM
i wouldnt beable to put the air box on due to the k&n fipk i installed. but ill try unhooking the battery. neg & pos? or just the neg?
Old Mar 22, 2008 | 09:01 AM
vita's Avatar
just neg is all thats needed. Give that a try first and let it sit for an hour or two.
Old Mar 22, 2008 | 09:58 AM
mickey's Avatar
basically make sure that anything you unhooked is hooked back up or parts that are hooked to the intake system are hooked back in.
also make sure you didnt damage the maf , or that other small one i cnat think of it's name right now.
you might also go have codes pulled on it from someplace like autozone or advanced and see what they are you might have somthing that is real stupid here like a lose plug or somethign that you unhooked and forgot becuse it feel down in to teh motor bay out of site.
I have done this before where a wire will fall out of site and things go nuts and you have to scratch your head for a hour over looking everythign agian and again to find out what is wrong.
Good luck and please keep us posted I have a 03 SS and i did mine with absoluty nothing wrong matter of fact it started to idel better and sounds like a vacume cleanner. it sucks so much air.
Makes me wonder why they chose to pretty much choke them out in the factory.
scc24540
Dec 20, 2008 12:05 AM
chevyrider08
Nov 27, 2008 07:21 PM
jayturk99
Jul 17, 2008 07:46 PM
Superdave
Jun 29, 2008 09:05 PM
nanahippie
May 25, 2005 05:42 PM
