in line fuse probs HELP please...
Old Nov 20, 2008 | 06:51 PM
chevyrider08's Avatar
Default in line fuse probs HELP please...
anyone kno the proper sizes fuse for 1600 watt amp should be...i recently burned my in line fuse holder...didnt really burn fuse but the holder was melted a lot...the part that is close 2 battery...please someone help before i keep wasting money on fuses lol...
Old Nov 20, 2008 | 07:30 PM
kweef's Avatar
Default RE: in line fuse probs HELP please...
u burned ur fuse holder? well what amp fuse were u using? i would obviously start with that...i believe my fuse is a 75 A and i have a 1500 system (I am not sure tho so ill have to double check) hopefully someone can help
Old Nov 21, 2008 | 07:04 PM
i had a 100 amp fuse in it...but lik the fuse never blew...it just melted the housing...any ideas on that 1?
Old Nov 22, 2008 | 08:09 AM
RocknSS04's Avatar
Soundz like the holder was under rated for the size of the fuse you're running. Need to go to a bigger fuse holder. I'm having problems with my Moster fuses BREAKING, not blowing. Stay away from the Monster fuses
Old Nov 22, 2008 | 02:00 PM
well ive bought a street wires holder n fuse...rated at 150 amp...**** 4 the price it better not melt...
Old Nov 25, 2008 | 11:26 PM
drewskie043's Avatar
i don't know much about wiring amps or systems in general,but if you have a 1600 watt system running off of lets say 13V that would be 1600/13 = 123 Amps being that Amps = watts/volts. so if you run a 75A or 100A fuse, that will burn up no question. go with a fuse bigger than 123A and try that out. hope this helps!
(a handy way to remember the power equation is 'PIE' or P=IE, with P=watts, I=amps, E=volts)
Old Nov 25, 2008 | 11:43 PM
kweef's Avatar
good call drew i should have remembered my physics a lil better. when workin on cars u never use a fuse that is rated higher than spec...it can do absolutely no damage or it can literally melt an entire wiring harness 2gether (yah try replacing that) so i would suggest that u check the rating of ur holder and use a 125 amp fuse...and i checkd my fuse and its only 100 A but thats what the capacitor is for
Old Nov 27, 2008 | 05:55 PM
alrighty then got the new fuse...no problems yet...so thankz guyz
Old Nov 27, 2008 | 07:21 PM
RickCoMatic's Avatar
You never "Waste Money" on Fuses.
Fuses are Insurance Policies against needing to replace a Wiring Harness.
You may pay a few premiums. Short money for Fuses.
Big Money for wiring Harnesses.
oaky812
Aug 7, 2024 03:49 PM
jayturk99
Jul 17, 2008 07:46 PM
Superdave
Jun 29, 2008 09:05 PM
SilentWutch
Mar 22, 2008 09:58 AM
nanahippie
May 25, 2005 05:42 PM
