6th Gen ('00-'05): Abs/trac off/service traction system
Is there any real difference between driver's side and passenger side ABS sensor harness? GM has them listed as seperate parts #s 10340313 & 10340314
THANK YOU IN ADVANCE!!!
I don't recall the connector being different (as a wheel hub with integrated ABS wheel speed sensor is the same for both sides of the car), my guess is the color coding for the wiring is different.
Opinion Needed: ABS and Traction Active Issues
ajay654
Jun 25, 2020 12:09 PM
6th Gen ('00-'05): abs/service traction issue
dave countie jr
Apr 10, 2013 03:04 PM
