ABS and Traction???
Old Nov 6, 2009 | 09:11 AM
1MonteChick's Avatar
Default ABS and Traction???
Hi guys, sadly my 2000 Monte SS is in the shop for repairs again but i've had an ongoing issue with the traction system! As soon as i turn my car on the ABS and Traction Control shut off and the message center claims that i need to "Service Traction System" however there are no codes. i've heard this has happened before with many other Monte's. So what's the deal? Bad hub bearing? Bad harness? Maybe it's the ABS/Traction computer module?
Old Nov 6, 2009 | 04:40 PM
RocknSS04's Avatar
Probably what I just told Joe Bloggs. It's more likely than not the connector to the speed sensor in the hub. But you don't say where you're from If you're from the north, you could have a corroded speed sensor, and they are not repairable. How many miles on the Monte?
Old Nov 8, 2009 | 10:20 AM
i've got 250,000 kms on it. my mechanic put a new abs pump on it so that was a little expensive. i haven't got it back yet but i imagine it worked cuz he didn't call me to say i needed new parts. he's my cousin so i trust he won't gyp me on anything... and i live in manitoba
Old Nov 11, 2009 | 10:14 PM
04MonteLS's Avatar
How much was it? I'm getting the same thing in mine and I pulled a code U1040, Loss of class 2 communication with the electronic brake module.
Old Nov 12, 2009 | 08:50 AM
Usually when that happens it's a sensor gone bad somewhere, likely to be in the hub assembly and then you swap that out.
Old Nov 14, 2009 | 07:06 PM
MyMonteSS's Avatar
I have the same hub problem. I'm curious to know if the rear hub assembly would be hard to replace with moderate mechanic abilities?
Old Nov 15, 2009 | 11:54 PM
the part was a little under $500 but he had to additional wire work to fix the traction portion.
installing a rear assembly is way less work than a front one. but i wouldn't try it myself. if you're pretty confident with cars than i'd say go for it!
Old Nov 16, 2009 | 02:44 AM
MyMonteSS's Avatar
I'm quite confident, and one of my buddies is even more confident so I'm thinkin we would be able to get it with the two of us.
Old Nov 16, 2009 | 09:25 AM
Doing it yourself it should be able to be done for anywhere from $60-$120.
http://www.paulstravelpictures.com/G...ent/index.html
(remember the GP is the same)
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
Pure2sin
17
Dec 15, 2009 10:38 PM
thomasnchy
Jun 5, 2008 08:23 PM
tridski
Jun 26, 2006 09:55 PM
