Abs/trac off/service traction system
Old Oct 18, 2022 | 06:01 PM
towgnr's Avatar
Default Abs/trac off/service traction system
Howdy, y'all!
02 SS Limited Edition 191k real miles that I've owned for over five years. In that time I've replaced almost the entire front end. Showed the ABS/TRAC OFF/SERVICE TRACTION SYSTEM group on the dashboard whenever I shift from reverse to drive with the steering wheel cut hard right. Replaced both wheel hub+sensors with new Moog parts this past weekend, did not solve the problem. WHAT ELSE COULD IT BE???
TIA-Charlie
Old Oct 18, 2022 | 07:43 PM
If you can, get a scan tool that can read the EBCM (ABS computer). It will have codes for why those lights activated. My gut says you have a damaged ABS sensor wire that goes to the EBCM. But I would check the codes before proceeding. I know a lot of software for bluetooth readers can do it, a GM Tech II and a few other scan tools.
Old Oct 18, 2022 | 11:09 PM
towgnr's Avatar
Thank you, Sir. You rock!
that silver monteSS
May 4, 2015 08:13 AM
Watty
Feb 2, 2015 03:37 PM
dave countie jr
Apr 10, 2013 03:04 PM
Nova1585
May 6, 2011 10:24 PM
1MonteChick
Nov 16, 2009 09:25 AM
