A.B.S and traction light
Old Sep 2, 2008 | 08:19 PM
1sickazmonte's Avatar
Default A.B.S and traction light
hey, i have a 2005 tony stewart edition monte, i have a ? ... i went on a 3 day vacation and when i came back home i got in my car and when i started it the chime started going off and when i looked at the dash my A.B.S and traction light were both on steady. i want to know why that happened, before i take it to get serviced. i dontknow but would changing the pads fix it??????
Old Sep 2, 2008 | 10:40 PM
ChucksMonte's Avatar
Default RE: A.B.S and traction light
I have the same problem...its either a ABS harness or a ABS sensor has gone bad...
Old Sep 17, 2008 | 01:03 AM
roflcopter's Avatar
As far as I know, ABS and traction control are in the same leagues as far as wiring and computer and such are concerned, so it could indeed be a bad sensor, or somethings up with the computer (not very likely, though). See if you can get a diagnostic reading from it, but before you do, why not test out the ABS and traction control to see if they are truly malfunctioning (try to do a burnout, stop really hard, etc...lol) i don't believe changing the pads would do any good, unless they need it, because I don't think there is a sensor for actual brake pad wear...it would be nice though... It could just be a wire, though, too, inside the wheel well that got worn or shorted or chewed.
mwmarshall
May 14, 2022 02:43 AM
Chris s
Jan 27, 2013 04:30 PM
smartin40
Feb 20, 2011 10:56 AM
thomasnchy
Jun 5, 2008 08:23 PM
97z34
Sep 22, 2006 10:40 PM
