ABS Sensor
Old Mar 3, 2014 | 12:34 PM
2002 SS's Avatar
Default ABS Sensor
Hey guys, my ABS light is on for the most part, but tends to shut-off intermittently when driving. I was thinking wheel hub is bad, but I never owned a 4 wheel disc-car. Could the rears be setting of the light, or could it be something else?
I read on the forum, chances are it's a wheel hub, but wanted some thoughts. Thanks
Old Mar 3, 2014 | 12:56 PM
Most likely, when it is a wheel hub, you will also have service traction control system.
Can you get the ABS code scanned?
Old Mar 3, 2014 | 01:07 PM
2002 SS's Avatar
Will a OBDII scanner read that as well? I had it auto zone, the guy turned on the ignition, but the ABS only lights up when started, so it only read the CEL.
Old Mar 3, 2014 | 01:47 PM
No it is usually read from different tools. It's not a standard OBD2 code unfortunately.
Henderson21
Nov 5, 2016 11:06 PM
moneylaw
Nov 27, 2014 08:00 AM
peterjwsong
Feb 20, 2014 06:36 PM
ecosta221
Aug 8, 2013 11:02 AM
jeff2425
Jul 6, 2008 04:20 PM
