6th Gen ('00-'05): ABS scan, shows rear left malfuntioning speed sensor
Old Feb 20, 2014 | 06:09 PM
peterjwsong's Avatar
Default ABS scan, shows rear left malfuntioning speed sensor
the shop has told me that in order to replace the rear left speed sensor, i have to change the whole bearing unit as well because they are attached to each other.
is this true?
can i just replace the sensor only?
Old Feb 20, 2014 | 06:36 PM
dbaldwin's Avatar
is this true?
Yup, gotta replace the whole hub, but the harnesses often go bad and are a much cheaper part to replace.
Henderson21
Nov 5, 2016 11:06 PM
Keem773
Mar 7, 2015 08:49 AM
moneylaw
Nov 27, 2014 08:00 AM
montejass
FWD Tech Guides '95-'07
18
Aug 11, 2013 06:12 PM
SSmokybear
Apr 25, 2008 06:13 PM
