Intake manifold leak
Old Sep 22, 2009 | 03:50 PM
sotmelo's Avatar
Default Intake manifold leak
when i took my car to get my MAF changed
the mechanic told me i had a leak in my intake manifold
so the coolant is leaking.
what do i do??
Old Sep 22, 2009 | 04:20 PM
Budsjlm's Avatar
replace intake manifold gasket
Old Sep 22, 2009 | 05:20 PM
lower intake manifold?
Old Sep 22, 2009 | 05:49 PM
MAMONTE's Avatar
Get the intake manifold gasket changed...its common on the 3.8L
Old Sep 22, 2009 | 07:53 PM
but which intake gasket? haha
Because if it's not the LIM but the UIM we could upgrade something while fixing the gasket...
Old Sep 22, 2009 | 08:22 PM
MAMONTE's Avatar
Ahh I like your thinking...LOL! Always thinking PERFORMANCE!
But more than likely it is the LIM that is the most common gasket to leak on the 3.8L...maybe this guy is somewhat luck and its the UIM and he can go do a few mods! wooohooo!
Old Sep 22, 2009 | 08:42 PM
Find out which one. If it's the UIM then HV3 while putting it on will give performance and change the gasket.
Mine was leaking too :P
Old Sep 22, 2009 | 11:15 PM
sotmelo's Avatar
im not that good with my car, but i think its the UIM
its the black plastic thats under the "3800 cover"
check this image, the red is what im assuming that is leaking
& the yellow arrow points to where i find traces of coolant
http://i44.photobucket.com/albums/f2...intakejose.png
Old Sep 23, 2009 | 07:56 AM
yes that black plastic thing is your UIM. It's actually basically just a stupid hallow cover that bounces air around.
If you want a performance boost + gasket change buy This HV3 Insert
Once you take the UIM off, you just take out the plastic runners (the black plastic inside the UIM throw those away, and replace that with this insert (takes 2 seconds to remove and put the insert in, then you just lightly bang it with your hand to get it to fit, being careful not to crack the UIM) and it comes with the new gasket!
Put back together, and no more leak and upper RPM response is better. (aka highway speeds)
Old Sep 23, 2009 | 08:08 AM
MAMONTE's Avatar
There you go! Fix the problem, and gain a few ponies while doing it!
