ABS Sensor
Hey guys, my ABS light is on for the most part, but tends to shut-off intermittently when driving. I was thinking wheel hub is bad, but I never owned a 4 wheel disc-car. Could the rears be setting of the light, or could it be something else?
I read on the forum, chances are it's a wheel hub, but wanted some thoughts. Thanks |
Most likely, when it is a wheel hub, you will also have service traction control system.
Can you get the ABS code scanned? |
(Post 601025)
No it is usually read from different tools. It's not a standard OBD2 code unfortunately.
