78-88 G body suspension
Old Jul 1, 2018 | 06:15 PM
Jeffs02rwdSS's Avatar
Default 78-88 G body suspension
I am looking for either a diagram or a picture of the front upper control arm and ball joint on either the driver or passenger side of a 1978-1988 G body car. Would be great if someone could pull off a tire and take me a picture. I put lowering springs in mine and the steering geometry is way off when wheels are turned. I'm wondering weather I have the arms on the correct side even though I marked them before painting and rebuilding. which is possible or do I need to get an adjustable upper arm. Hoping someone can help, if it matters they are Eibach spring which should lower it about 1 1/2 inches Thanks in advance.
Old Jul 1, 2018 | 06:53 PM
Smile
try this link on google and see if it helps you out?
these are only the images if you need tech then select the tab that says all.
https://www.google.com/search?q=1978...=1530489022829
Old Jul 1, 2018 | 07:04 PM
Thanks Dean, but most of them pictures show aftermarket control arms and I'm running factory at the moment .They have a distinctive shape and I'm questioning myself.
Old Jul 2, 2018 | 05:34 PM
I found a picture on the Car ID site by looking up a replacement control arm .
Cownuv
Jul 16, 2016 12:23 PM
claydoh
Nov 22, 2015 10:24 AM
David0556
Aug 3, 2015 08:38 PM
JC Colon
Jan 2, 2015 06:44 PM
HIxArsenaL
Aug 11, 2014 02:27 AM
