Lower rear control arm
Old Aug 1, 2015 | 12:04 AM
David0556's Avatar
Default Lower rear control arm
I need to replace the left (driver side) lower rear control arm. Do I R&R the control arm without jacking, with the weight on the wheel, or weight off?
Old Aug 2, 2015 | 09:17 PM
What year Monte? If you are talking '00-'07, you will definitely need to have the car raised, wheel off (or else the wheel will be in your way big time). The arm is held in by two bolts on the subframe and a nut at the steering knuckle.
The only repair I believe you might be able to do with the arm on the car is replacing the ball joint (but even that is a pain).
Before diving in, you may want to price a replacement arm (brand new, fully loaded). RockAuto.com is a good place to look.
For other years of Monte, I am betting you'll need the car raised and the wheel off (I'm not aware of any front control arm that can be done with the car on the ground and the arm still in the car).
Old Aug 3, 2015 | 06:44 AM
David0556's Avatar
Very sorry, forgot to add that it's a 98
Old Aug 3, 2015 | 08:38 PM
I'm pretty certain the '98 is very similar to most GM FWD cars. Best way to tell, get on the ground and take a peak.
weizie
May 23, 2013 01:26 PM
Chriswmasters
Mar 20, 2013 10:13 AM
undeadmetalshred
Feb 1, 2012 11:52 PM
monte67
FWD Tech Guides '95-'07
Jan 28, 2012 09:52 AM
dirtybird
Sep 26, 2010 12:48 PM
