2006 Monte Carlo Steering Noise
Old Sep 16, 2011 | 09:48 AM
Slugger088's Avatar
Monte of the Month -- August 2013
Default 2006 Monte Carlo Steering Noise
Hi all:
I have had this concern since I got the car. Basically when I am turning (usually at very low speed acceleration or deceleration and typically in light turns of the wheel or when applying / releasing the breaks), I hear a clunking type noise coming from the front of the vehicle and it can even clicking feeling can be felt in the steering wheel. I originally thought that this may be normal for a front wheel drive car with 'everything happening up front' but I thought I would see what others think about this.
I have come across a couple threads on this issue and I am wondering if this is the problem. (Intermediate Steering Shaft)
Image of the Intermediate steering shaft-Impala - GM Inside News Forum
https://montecarloforum.com/forum/ge...turning-21593/
Can anyone with a 2006 MC or knowledge on this issue confirm that it is my intermediate steering shaft? I was also told by someone that GM went cheap on these parts for that model year. My cousin has a 06 impala and I have also heard the noise in his car and felt it in the wheel as well.
What are my options to fix this? I do not want to order the same part only to have it continue. Are there any after market options for me? Or has GM had any new suppliers for this part?
please help! : )
Old Sep 16, 2011 | 09:55 AM
06MonteSS's Avatar
yep... it's the ISS...
Old Sep 16, 2011 | 01:18 PM
Ricks 2006 SS's Avatar
Yup I have the same problem !
Old Sep 16, 2011 | 01:34 PM
Go under the steering column, find the silicone boot, pull it back and expose the knuckle of the ISS. Spray white lithium, rotate the steering wheel, spray some more, rotate the other way, spray more.
Repeat every spring and you'll be fine.
Old Nov 20, 2011 | 02:42 PM
maddmaxx51's Avatar
Would this also be the same on my 2000 mc
Old Nov 20, 2011 | 09:43 PM
I didn't realize it was that easy to fix I need to do this one of these days
Old Nov 21, 2011 | 09:01 AM
It would be the same for anyone 2000+
SanJoseSS
Feb 1, 2013 01:29 PM
nat120
Apr 23, 2011 10:13 PM
slinkeey
Jun 24, 2010 12:25 PM
24_48Fan
Oct 20, 2009 02:34 PM
05SSMonteCarloSC
Sep 30, 2009 01:27 AM
