98 Z34 running problem
Old Nov 20, 2011 | 11:30 PM
puffins629's Avatar
Default 98 Z34 running problem
My car starts for about 2 sec and the it just dies no matter what I do. I just changed the computer on it about 3 months ago and had the same problem. The battery died and i needed to jump it then it ran fine. I disconnected the battery to try and reset everything and it didn't help. So now the car is sitting at my work with the battery disconected hoping it will help when I go back in tomorrow. I am just wondering if there are any other suggestions that can help me if this doesn't work tomorrow. PLEASE HELP!!!!!!!
Old Nov 21, 2011 | 01:00 AM
nitehawkjcb's Avatar
Unplug the MAF sensor, see what happens
Also check your fuel pressure
Old Nov 21, 2011 | 06:00 PM
puffins629's Avatar
I got fuel pressure and disconnected the maf sensor and nothing changed Idk what else to do.
Old Nov 21, 2011 | 07:56 PM
puffins629's Avatar
I have noticed since I have been trying this for a while I here 2 clicks right before it shuts down but I can't tell where it is coming from
Old Nov 21, 2011 | 07:57 PM
zipper's Avatar
If you unplugged the MAF and nothing changed, then that's your problem. You need to replace the MAF. When you typically unplug the MAF, your car will run like crap.
Old Nov 21, 2011 | 10:17 PM
puffins629's Avatar
It can't run long enough for me to tell like I said it only runs for maybe 2 sec
Old Nov 21, 2011 | 10:27 PM
mrl390's Avatar
Does it fire right up and then die or take some coaxing to get started? When did you check the fuel pressure? With key on engine off or while cranking?
Old Nov 22, 2011 | 07:27 AM
puffins629's Avatar
It starts right up and you can rev it then after 2 sec it dies every time and we checked fuel pressure while cranking/ starting. I did try reseting the security system but that didn't work and I don't have a security light on or any codes.
SouthCarolinaSS
Jan 12, 2014 03:26 PM
RickyakaPedro Keller
Sep 4, 2012 10:08 PM
97MONTEZ34
Apr 23, 2012 12:28 PM
Cheeko
May 24, 2011 01:08 PM
polososa
Mar 2, 2010 09:11 AM
