2001 3.4 coolant in oil
Easiest thing to do is shoot RockAuto an e-mail to verify which one is aluminum. They will respond rather quickly with all the info you need.
Hmmm..... I will have to check that possibility out. I know the engine has a coolant throttle body bypass to protect against parts freezing. I have a 2001 with the 3.4 engine. I have zero white smoke from the exhaust but antifreeze is getting into the crankcase somehow.
Thanks for the info!
In the 3800 Series II L36, the only coolant passages in the plastic upper intake are to just run coolant through a pocket/bypass in the throttle body (again, no coolant flows around the EGR). I have heard of those passages cracking like you mentioned.
Yeah my bad...I should proof read my post before posting. I was refering to the coolant passage you were talking about. When I posted the response I had just got home from work and just finished replacing an EGR cooler on a Cummins diesel. I must of had egr on the brain...LOL
satara_edem@hotmail.com
Dec 22, 2009 10:59 AM
carajean
Jun 23, 2009 02:21 PM
