high output alternator options
Old 01-26-2012 | 10:06 PM
Milhouse's Avatar
hey this helps and for the 18$ you spend it is worth it all day i got the stage 1 and it tool me from 13.9v to 14.5 and i am using it in tandem with my 200 amp hp alt in my Monte .I have to say i was skeptical but it was only 18$ so I took the chance and it is totally wort it !! It does work .
Easy Performance - Alternator Voltage Booster #
What alt do you have? I didn't look at the link you posted but is it basically a larger gauge wire that runs from the alt to the battery?
  #32
Old 01-26-2012 | 10:34 PM
Boxman420's Avatar
im curious about this thing also... but my alternator already charges my batteries at 14.6 volts... and i get 14.6 at my rear battery so im not sure if it would do me a whole lot of good unless it was more of a stabalizer or something..
  #33
Old 01-27-2012 | 12:07 AM
Milhouse's Avatar
Might be worth a shot for just $18
Thanks for the link Blazed
  #34
Old 01-27-2012 | 11:44 AM
Blazed SS's Avatar
IT HERTZ
here is my HO ALT I had it done in Portland Or.
You can see the Voltage booster plugged in in this pic it takes less than a couple min to put on
all I know is that was where i was at before I put the voltage booster on and what it did for me (system on full at 1800 idle 13.3 ) it Totally worked to get just a little more charge out of the system and when I am running my system at full power I don't dip below 14.1v (1800 rpm) ,Idle at 14.5v (system running at normal vol), and driving at 14.7v (system at normal vol)
  #35
Old 01-27-2012 | 11:52 AM
Boxman420's Avatar
yeah hell i ordered one lol. . if it boosts me up .1 voltage ill be a happy man!
edit. nice blazzed! id be happy if i could stay in the 13s.. it likes to drop down to 12.8. so hopefully this will help!
  #36
Old 01-27-2012 | 11:59 AM
Blazed SS's Avatar
IT HERTZ
that is what I thought 2 man it was worth a shot . I did read allot of reviews before I got it (because i did not think it would work )
and they all said it worked some .3v and as much as .7v to .9v v
The stage 2 does 1.v if I remember right and stage 3 is like 1.5v
  #37
Old 01-27-2012 | 12:13 PM
Boxman420's Avatar
i looked for reviews then i just said screw it. its cheap. its worth a shot! i dont want up to a .7 increase lol. that would suck. but anything could help i guess.. man at 1.5V increase your better off just running a external voltage adjuster
  #38
Old 01-27-2012 | 12:33 PM
Blazed SS's Avatar
IT HERTZ
i looked for reviews then i just said screw it. its cheap. its worth a shot! i don't want up to a .7 increase lol. that would suck. but anything could help i guess.. man at 1.5V increase your better off just running a external voltage adjuster
yes from what i know you would want a external voltage adjuster in that case I think any thing over 15v or 15.1
if you get the .7v increase and it is too much you can all ways just put it on at shows or as you know when you are driving you DTD Lights are on heat or ac power windows stereo is on etc ,etc. are on so that should keep you under 15v
eviling
07-26-2010 11:30 PM
NYGiantsfan
02-03-2010 09:26 AM
Willis_454
03-12-2009 05:58 PM
steptoe
11-26-2006 12:38 PM
