FOG lights on '04 SS?
Hello all. Is there a module or something out there that will allow the fog lights to turn on without having to hit the button after startup? Or can the switch be rewired to default the fog lights to the ON position?
Thanks.
Thanks.
I have wanted to do it as well, but I don't want to loose ability to control the fogs (I just want them to default "on"). I have spent a little time trying to dissect some things but yet to get 100% there. I believe the relay for the low beam headlights are in the fuse panel near the fog button. If that is true, I believe it would take being able to create something that when that relay is energized/triggered, have something take that trigger (which is constant) and perform a momentary trigger to activate the fog lights (as if you pressed the fog button). If that can be done, then when you want the fogs off, it's a simple push the fog button and the fogs are off.
But I have yet to confirm when I thing as far as the relay and I don't know how to take a constant and translate to a momentary trigger.
It's a shame that someone like SLP didn't come up with a module that could plug in to default the fog lights to the ON position. They made a module that did that for the traction control on f-bodies. It sucks that you have to manually turn on the fog lights after startup.
