Fog lights
Old Apr 11, 2012 | 02:02 AM
05MCdriver's Avatar
Default Fog lights
I have the 05 LS and I kno it has the spot for the fog lights.. Just wondering if anyone has added them and how much it ran you to do it.
Old Apr 14, 2012 | 02:41 PM
aussiek2000's Avatar
I put fog lights on my 04 LS. Bought some fog lights online, ran the wiring and installed a switch and relay. Took 2-3 hours and less than $100. I did have to make brackets to hold them, which required metal bending and welding knowledge.
Old Apr 14, 2012 | 09:51 PM
Bait's Avatar
I like it.
Old Apr 14, 2012 | 09:56 PM
Bait's Avatar
What make and model do you have? Part number if available.
Old Apr 15, 2012 | 06:03 AM
All that I remember is that they are 2.5 or 3"" pilot automotive brand. All I use from the kit was the light itself. I used my own wiring and switch and made brackets. I will get a measurement today on the light.
Old Apr 15, 2012 | 08:31 AM
daves92camaro's Avatar
i took factory ones....and got the plugs and just spliced them into a harness off a power source to a relay to a switch works great..didnt want to mess with the bcm and stuff
Old Apr 15, 2012 | 09:25 AM
Mike 00LS's Avatar
I added factory ones to my 2000. I bought them off a member on here - did have to fix the drivers side bracket a bit first. I just spliced them into the low beams so they come on at night with the auto headlights (legally fog lights have to turn off when the high beams come on) plus with high beam DRLs, I didn't want them on 24/7, nor did I want to wire up a switch.
Old Apr 15, 2012 | 12:17 PM
I also added factory ones because the factory hole is oval, everything else just looks weird.
Old Apr 15, 2012 | 05:30 PM
mairj40's Avatar
Do Grand Prix driving lights work in our Montes?
Old Apr 15, 2012 | 05:55 PM
Jparks's Avatar
If I'm not mistaken your monte (2003) requires (9006⁄HB4) or (9005⁄HB3)
