Resonator removed today
Old Aug 6, 2011 | 12:55 PM
Default Resonator removed today
Won a small amount of $$ at casino and thought I would hit the muffler shop and have the resonator removed. He said it would make a noticeable difference. At idle its very little but when kicking it, it is a big difference. I like it and they only charged me $30. They said they would install an offbrand set of Flowmasters for $200. They say theirs sound better. I dont know but said I would think about it.
Old Aug 6, 2011 | 01:20 PM
Mr.Monte's Avatar
any check engine light??
Old Aug 6, 2011 | 01:27 PM
I did the same on mine... But you need to re-boot your system. disconnect the negative ground on your battery wait 30 min, re-connect, then re-connect n start her up
Old Aug 6, 2011 | 01:58 PM
Tad, why do I need to do that? I dont have a check engine light on or anything. Just curious why I would need to do it. Thanks
Old Aug 6, 2011 | 02:04 PM
LuSe4's Avatar
Yeah Tad, why did you do that? A resonator removal won't set any codes.
77GP, your exhaust is stock, right? Is DOD (AFM) more annoying now when cruising down the highway?
Old Aug 6, 2011 | 02:11 PM
Yes, mine is stock. Havent had it on the highway yet, but when I do I will post results. I may just take it out here shortly as the interstate is only 5 minutes away. I wouldnt think it would be a problem since it isnt that loud but I will check it and post.
Old Aug 6, 2011 | 02:13 PM
All I know is that when I installed my cat backs I had to do it and when the guy at the shop took out my resinator he told me to do it. There is a post here from some one else here about it I'll try to find it.
Here it is....
always a good idea to let the system reset after adding something
This is from the Magna Flow Thread. Now I could be totally wrong but when dealing with exhast mods I have been told to do this. I know you are REMOVING the resinator and placing in a stragih pipe but this still affects back pressure
jeffsmonte
Nov 21, 2022 07:34 AM
Brendocee55
Oct 13, 2015 04:35 PM
vincenti
Sep 13, 2011 10:02 PM
06BlackSS
Mar 12, 2007 01:47 AM
White05LT
Feb 9, 2007 05:22 PM
