3800 top speed/ limiter removed
Old Apr 12, 2009 | 02:35 AM
vincenti's Avatar
Default 3800 top speed/ limiter removed
does anybody know what the top speed of a 3800 monte (non-supercharged) with the limiter removed is? thanx
Old Apr 12, 2009 | 04:26 AM
Originally Posted by vincenti
does anybody know what the top speed of a 3800 monte (non-supercharged) is? thanx
Hi Vincenti, and Welcome to the MCF
I've read from 112 to 122 MPH on Stock 3.8L
Mod's or a Chip will change Top Speed 4 Sure
Check out below infor
Select a Year to Shop for Your Monte Carlo Performance Chip
Don't see your year? Try searching our entire Auto Parts Catalog.
Chevy Monte Carlo Performance Chip
ECU modifications aren�t just for hot rodders�anyone who tows a trailer or wants better mileage can benefit too. We'll go out of our way to help our customers with their Chevy Monte Carlo Performance Chip questions. For help, information or suggestions, call us toll-free! Who else can beat that? Did you know that we have one of the most secure sites on the entire Internet? That's right! Your Chevy Monte Carlo Computer Chips Performance order is guaranteed to be protected! Most of our performance chip products are 100% street legal. Some are intended for race use only so be sure to check out the detailed descriptions to find the one that suits you best. It doesn�t matter what type of performance chip you need, whether for an import or diesel engine, we have what you need right here. And, you�ll be glad to know that every performance chip is discounted up to 70% off retail prices! Don't hang back any longer to purchase your new Chevy Monte Carlo High Performance Chips, give us a call toll-free today! You won't have to worry about the shipment of your Chevy Monte Carlo Car Performance Chip because we will deliver it to you wherever you are! All Chevy Monte Carlo Aftermarket Performance Chip order info you provide to us is transmitted using a 256-bit encryption server, so no information can be altered. Every Chevy Monte Carlo Custom Performance Chip you find in our broad inventory is guaranteed to have passed every high standard of product superiority! Here at Race Pages, we strive to be the best internet auto parts supplier you've ever come across. Great customer service isn't only our goal, it's our priority.
+ enlarge image
Superchips Flashpaq Power Programmer
App: 2006-2007 Chevrolet Monte Carlo
Brand: Superchips
Part #: 2825
Notes: SUPERCHIPS FLASHPAQ TUNER -- Increases power and torque, improves fuel economy and optimizes drivability; Eliminates speed limiter and skip shift, adjusts shift points and rev limiter, recalibrates speedometer for rear gear change and controls the cooling fan to lower the running temperature; Features diagnostic trouble code reading capability; Internet updateable; Highly versatile with three available performance settings; Easy installation with no tools required; With Superchips' limited warranty.
Series: Flashpaq
Price: $348.68
Quantity
MakeModelYear RangeChassis/EngineChevroletMonte Carlo2006 - 2007SS; 8Cyl 5.3L GAS, FI, VIN "C";
+ enlarge image
Superchips Power Programmer
Brand: Superchips
Part #: 2950
Notes: SUPERCHIPS CORTEX PROGRAMMER -- An elegant, sleek and innovatively designed programmer with diagnostic library that retrieves, displays and clears diagnostic trouble codes; Logs performance times and speeds; Displays and stores PID data; Internet updateable with the latest calibrations; Adjusts shift points, enhances shift firmness, eliminates speed limiter, adjusts RPM limiter and corrects speedometer for taller tires and gear ratio changes; Offers a choice between three available tuning levels; Not legal for sale or use in California on pollution controlled motor vehicles; Easy installation; With Superchips' limited 1-year warranty.
Price: $394.68
Quantity
MakeModelYear RangeChassis/EngineChevroletMonte Carlo2006 - 2007SS; 8Cyl 5.3L GAS, FI, Naturally Aspirated, VIN "C";
+ enlarge image
Hypertech Power Programmer
App: 2001-2005 Chevrolet Monte Carlo
Brand: Hypertech
Part #: 32002
Notes: HYPERTECH MAX ENERGY POWER PROGRAMMER -- Comes with a USB cable for internet upgrade; Extracts every energy possible from fuel molecules; Increases miles-per-gallon at part throttle and horsepower at wide-open throttle; Raises the top-speed limiter to match high performance tires' speed rating; Improves the engine's rpm limiter for increased performance; Adjusts individual automatic transmission shift points and shift firmness; Recalibrates speedometer and odometer for non-stock tire sizes and gear ratio changes; Reads and clears diagnostic trouble codes and turns off check engine lights; Lowers the cooling fan on and off temperatures to match the thermostat rating; Adjustable settings or revert to stock calibration any time; With Hypertech's limited lifetime warranty.
Price: $379.99
MakeModelYear RangeChassis/EngineChevroletMonte Carlo2001 - 2004SS; 6Cyl 3.8L GAS, FI, Naturally Aspirated, VIN "K";ChevroletMonte Carlo2005LT; 6Cyl 3.8L GAS, FI, Naturally Aspirated, VIN "K";
+ enlarge image
App: 2004-2005 Chevrolet Monte Carlo
Brand: Hypertech
Part #: 33002
Notes: HYPERTECH MAX ENERGY ECON POWER PROGRAMMER -- Specially Designed To Extract Every Bit Of Energy Out Of Every Molecule Of Fuel For More Miles Per Gallon At Part Throttle And More Power At Wide-Open Throttle, Features Optimized Tuning For Regular Octane Gas Vehicles And Fuel Programs A And B For Diesel Engines, Reads And Clears Diagnostic Trouble Codes And Will Return The Vehicle To Stock Settings With Just The Push Of A Button, Internet Updateable To Raise The Top-Speed Limiter And RPM Rev Limiter, Correct Speedometer/Odometer, Adjust Transmission Shift Points And Firmness, And Lower The Cooling Fan On/Off Temperatures, A Perfect Upgrade For Vehicles With The Easy Plug-And-Play Installation, With Hypertech's Limited Lifetime Warranty
Price: $329.99
MakeModelYear RangeChassis/EngineChevroletMonte Carlo2004 - 2005SS; 6Cyl 3.8L GAS, FI, Supercharged, VIN "1";
+ enlarge image
Brand: Hypertech
Part #: 33002
Price: $329.99
Old Apr 12, 2009 | 09:47 AM
Dunno if the monte's are different, but my 00 and 03 impala 3800 NA's were both ~105 stock. Never really looked at a tune for a monte 3800 though...
Old Apr 12, 2009 | 01:07 PM
montecarlo01ss's Avatar
its gear limited to 135 with 3.29's, do not let it shift into 4th/overdrive, bad for the tranny... why do u need to go that fast anyway??
Old Apr 12, 2009 | 07:29 PM
vincenti's Avatar
thanx for the info all. I really have no desire to go 135. just wanted to know what kind of "oomph" these motors have.
Old Apr 15, 2009 | 05:56 PM
montecarlossfan's Avatar
def past 140 haha...I buried my speedo once ...
Old Apr 16, 2009 | 09:28 AM
downhill?
Old Apr 16, 2009 | 07:12 PM
no on a flat /slight incline stretch of highway...
Old Apr 17, 2009 | 12:57 AM
smart move
Old Apr 17, 2009 | 07:34 AM
vincenti's Avatar
i did a little math and I figured if these cars roll 80MPH at 3000RPM in overdrive couldn't it do around 160MPH at 6000RPM (redline) if you allowed it to go into overdrive? why's it bad to let it shift to overdrive at these speeds? once again, just curious. going faster than 85MPH makes me panic like a little old lady afraid of rain. thanx
