Opinion Needed: I bought an 02 Monte Carlo and the keys were lost/stolen, how can I fix?
Old Aug 23, 2019 | 02:14 PM
Crarydalton's Avatar
Default I bought an 02 Monte Carlo and the keys were lost/stolen, how can I fix?
Is there a video on how I can drill out ignition or is there a way to remove and replace?
Old Aug 23, 2019 | 02:18 PM
VIN + call to the dealer can get you keys.
We can not provide instructions on how to drill out an ignition online lol
Old Aug 24, 2019 | 08:47 AM
Jeffs02rwdSS's Avatar
There is somewhere in the forums (not sure where) that does go through the steps to drill and remove the ignition switch from the wire harness. It is the only way to remove the switch if the key no longer works(in my case) or they are lost. It's not super difficult just need to take your time. I'll see if I can find my old key tumbler so you can see where to drill through Good luck
Old Aug 24, 2019 | 04:35 PM
As Chibi said take you VIN # to the dealer and they can get a Key made to fit the Car. They will need to send off to GM to the get the thing made. Then everything stays the same. When you mess with it you create more headaches for yourself.
Old Aug 25, 2019 | 09:42 PM
Here's the procedure to drill out the ignition switch to remove from the wire harness. Post #3 3 by Lougreen03 https://montecarloforum.com/forum/ne...-2003-a-37239/
Old Sep 2, 2019 | 05:19 PM
I agree, VIN and a trip to the dealer (bring your title for proof of ownership). Odds are they can re-produce the key right there (I know people that have had that done). Quicker, easier in my book.
If there is still a problem, as Jeff mentioned, it's not too tough to remove the lock cylinder and just change it out.
Household6
Dec 2, 2017 08:57 AM
hauntedtexan
Feb 24, 2016 08:47 AM
shiz0id
Aug 28, 2015 06:03 PM
bwill314
Oct 19, 2014 12:15 PM
scottsmonte
Jan 31, 2011 12:11 PM
