5th Gen ('95-'99): Missing the resistor key
I bought a great little 96' Montie and it drove great, then i lost the key and have no way to get a new one cut since the GM dealer wont cut a key for a car older than seven years, I also heard that you need the key to replace the ignition switch? If so, is there a way to remove the ignition switch by way of the steering column?
Thanks in advance guys!
cheers!
Jacob
cheers!
Jacob
First, find another dealership. I know a guy that had a brand new key cut for a '91 Cadillac like 5 years ago. As long as you have proof of ownership, they should do it.
I am not familiar enough with the ignition switch on a '96 Monte, but I am sure if you can find the shop manual, there is probably a way to pull the lock cylinder out without the key. But if the issue is you just need a new key, press the dealership. And if that dealership won't do it, ask for a manager and if they still won't, go to another dealership. The car is old, but not that old.
You can order one (I believe Helms Publishing makes them), Google search or hit YouTube. Someone may have posted the info you need (may not be for a Monte, but another GM with the same design).
I'd still push for the dealer to cut a key if a key is all you need.
This thread is very misleading, the poster is referring to a 96 Monte Carlo and the title has 7th gen (06-07) Could a moderator get this into the right section/gen list. A moderator even replied to this.....
Keep up the good work guys/gals.
