comparision photos with HIR (yes R) lights
Old Jan 3, 2008 | 08:00 PM
2000LS's Avatar
Default comparision photos with HIR (yes R) lights
well theres some old tech out there thats new to me. its called HIR. i took some pics so others can see a comparision of the bulbs.
left standard bulb, right HIR
left side standard bulb, right phillips hi-vis +30%
left HIR, right phillips hi-vis +30%
both phillips hi-vis +30%
fog lights, 880 left, 893 right
WARNING - the jury is actually still out on the 893 bulbs, for all i know they'll melt something, or everything.
Old Jan 3, 2008 | 08:01 PM
2000LS's Avatar
Default RE: test post
deleted
Old Jan 3, 2008 | 08:02 PM
2000LS's Avatar
deleted
Old Jan 3, 2008 | 10:39 PM
2000LS's Avatar
could anyone tell me how to make photos part of the post instead of thumbnails?
Old Jan 3, 2008 | 10:46 PM
Default RE: comparison photos with HIR lights
What worked for me was after you post the thumbnail image, click the thumb. Then right click on the image and copy. Edit the original post, right clickand paste the copied image into the post. Click ok to post the edited message.
Old Jan 3, 2008 | 11:18 PM
2000LS's Avatar
thanks taz, figured out that doesnt work in firefox, but works real nice in explorer.
Old Jan 4, 2008 | 12:45 PM
rj's Avatar
rj
These aftermarket bulbs, are they plug n play? No ballast to add or flux capacitors?
Old Jan 4, 2008 | 06:52 PM
2000LS's Avatar
plug n play. hir = halogen infrared reflecting. basicly, they're more efficeint bulbs. the bulbs have an almost clear coating in them that reflects some or most of the infrared light that all halogens make, keeps the filiment hotter, so less energy is used heating the element, so using the same wattage you can produce more light.
they are, almost but not quite plug n play. you have to trimone of the plastic tabs on the base to make them fit. i spent less than a minute with side cutters modifying the lights to make them work.
the bulb number is 9012 = 9006 and if you want high beams 9011 = 9005. you can buy em off ebay, just search for "9012 HIR" they sell the 9011 also. i hear you can also buy the 9012, not 9011, from john deere dealers, they use them on thier 9000 series tractors.
rg9johns
Aug 22, 2014 10:46 PM
Nov 14, 2012 07:31 AM
PinklySmooth
Jan 26, 2011 12:23 PM
Submariner
Jul 3, 2008 01:10 PM
BeachBumMike
May 11, 2008 12:14 AM
