turbo or super for 07 5.3 v8
#51
RE: turbo or super for 07 5.3 v8
but the supercharger will. since the supercharger will sit ontop were the intake manifold is the dod system is underneith. since you will need to use an ls6 superchager you will have to make many modifications to the system to make it work.
Also, if you wanted to stick with a positive displacement blower- you could remote mount it (used to be a 3100 kit like that- where it dumped into a plenum, and then was piped into the stock TB)- or you could make a custom upper intake manifold (and need a bigger hood, or hole in the hood like that 3.4 dohc monte).
looking at upwards of 8000 bucks.(superhcarger 10000)
#53
[IMG]file:///C:/DOCUME%7E1/test/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]here is a turbo, says it is safe for a stock motor. dont know about the tranny.
http://www.turbokits.com/monte_carlo_turbo_kits.html
#58
For a company to source all the parts for you, $900 + gaskets & fluids:
www.wbodystore.com (under superchargers)
For you to source the stuff yourself- the parts can run ~$500 or so depending on what you can find.
#59
Top Swap for sale
SSM90 Kit for sale
And another top swap for sale
These are for sale literally every other day.
Top swaps generally go for about $500 depending on the mileage of the supercharger and heads.
-Riggs.
SSM90 Kit for sale
-Riggs.
Mr.Monte
12-22-2011 12:00 PM
04MonteLS
07-01-2005 03:00 PM
04MonteLS
06-04-2005 11:17 AM
