engine swap questions.
Old 05-01-2015, 06:57 AM
Monsterh's Avatar
Well how difficult would it be for me to just put a supercharger on my series 2 3800 engine. What kind of supercharger could I put on it and what else would I have to do to the engine?
Old 05-01-2015, 09:15 AM
nitehawkjcb's Avatar
Do a search for "top swap", you basically need the heads, LIM, s/c from an L67
Old 05-01-2015, 01:34 PM
Monsterh's Avatar
Default n
Alright another questions What exhaust sytem would be best ? I've been looking at magnaflow and corsa exhaust.
Old 05-01-2015, 04:03 PM
After the cat, exhaust basically comes down to your preference on sound. Before the cat you have the u-bend and front exhaust manifold that are restricting. A plog and downpipe will solve that issue or a set of headers and matched downpipe.
Old 05-02-2015, 09:00 PM
Unless there is something wrong with your existing 3800, why not just top swap it with the supercharged top end?
This would be a lot less work than doing a full engine/trans swap and far cheaper. You basically just need the heads on up from an l67 as well as the balancer, etc. People frequently sell the parts to do this on the various forums or you can go to a local junkyard and get it yourself. I've seen all of the parts to do the swap for under $500- try getting an l67 and 4t65 HD for that. Plus you get to keep your higher compression and higher sprocket ratio on the drive chain in your trans. Totally different if your current engine is toast though.
As for some of your other questions-
-Chibi is right, you want an l67 not an l32 if you're going to do a swap. You can't use the l32s electronic tb, and it only makes a small amount more power. An l67 would be easier to install and would be cheaper since they're much more plentiful.
-Exhaust, I wouldn't waste money on any aftermarket catback. Power gains have proven to be near nothing. As long as your stock exhaust isn't rusting through, I'd just chop off the mufflers and replace them with whatever sounds best to you.
Old 05-02-2015, 09:21 PM
Monsterh's Avatar
Okay thanks I have been looking at top swaps and thats part of the reason my exhaust on my car is rusted through and starting to break off.
Old 05-02-2015, 11:01 PM
Do you have any localish shops that have a mandrel bender?
I just hate to see someone spend $1k+ on some name brand bent tubing, especially single exhaust.
Old 05-02-2015, 11:06 PM
or just find a good car in the junk yard? im sure it shouldn't be hard to do,id bring a battery operated sawzall so you wouldn't have to worry about trying to haul a whole exhaust lol,and just weld it back up,you would come out cheaper than a shop
01MoneyCarloSS
01-24-2012 02:16 AM
kc2kth
03-04-2010 12:38 PM
averagewhiteboy
01-08-2009 08:18 PM
Submariner
10-13-2008 10:43 AM
1999L36
12-15-2007 10:47 AM
Quick Reply: engine swap questions.
