Top Swap Questions!
Old Dec 3, 2007 | 02:16 PM
1999L36's Avatar
Default Top Swap Questions!
My roommate has a 2004 s/c Monte Carlo but he is putting in a turbo kit but he wants to give me his super charger setup with lower and upper intake and all that stuff but i wanted to know if i can take the top of my 99 3800 from a Buick Lesabre and turn his l67 into a l36 and vise versa with my l36. Any comments will help thanx.
Old Dec 3, 2007 | 02:27 PM
Mac7504's Avatar
Default RE: Top Swap Questions!
Umm I would think he would have to use his blower casing as an intake mani. Unless he getting the sheet metal modded one.
Old Dec 3, 2007 | 02:37 PM
Cowboy6622's Avatar
the only thing the same about a L36 and L67 is the block. they timing is different, the compression ratios are different.... not to mention the PCM's tuning. beleive it or don't, since the L36 has a higher compression, it can benefit more from the supercharger than the L67 can. plus, for it work on your car, you got to change the fuel rails? i believe.... basicaly, what your saying to do is a little on the impractical side... i think he hsould just keep it on... have both
Old Dec 3, 2007 | 02:58 PM
1999L36's Avatar
yea i know the compression and all that is diffrent pretty much im just wonder if it can be done caues we pretty much have all the parts and i can have my car tuned and even fuel rail is not an issue we have that but if i run the zzp 4.2 pully so im only hitting 5-7lbs then should my engine handle it. but one of the main reasons for all of this is so we do not have to use the blower as a intake manifold for the turbo setup
Old Dec 3, 2007 | 03:07 PM
Cowboy6622's Avatar
oooo.... okay.. yeah it shoudl work... you can actually buy all the stuff from ZZ performance to do it. what kind of turbo kit is your buddy getting and how much? I might be interested in getting a similar set up.
Old Dec 3, 2007 | 03:25 PM
1999L36's Avatar
im not sure what turbo he is gona run yet but i know he is gona custom fabricate most of the piping on his own or at are friends shop but when i get more details on what he is gona do and how much money ill let ya know
Old Dec 6, 2007 | 06:17 AM
bfurches's Avatar
...guess its only fair that I chime in...
First off...HI CASEY! (1999l36)
This is what casey was getting at.
He has a lesaber (as you all probably gathered L36)
I have a monte (l67)
I am going to the turbo route, and he has wanted to do a top swap for quite some time.
Essentially what he was getting at is that I refuse to ruin a good supercharger simply to run turbo (i.e. guttung the housing and cutting out the bottom for better flow).
I just want to run a tradiational intake manifold and port match it to the lower.
NOW....I am under the impression this is all very doable without even having to swap the heads (lower/ intake manifold, t-body,egr placement and etc needs to be rerouted)
Simply curious if anyone else has tried this.
We are well aware that tuning/ compression/ timing and other characteristics are different, which simply meens he neeeds to run less boost
Plus, I will most likely be obtaining a shop licensed version of HP Tuners.
As for my Turbo Build, once I have started compilingparts, I will post up in this section.
Old Dec 15, 2007 | 10:47 AM
RocknSS04's Avatar
Why don't you just swap engines, and save yourselves BOTH some grief!
DeanMachine
Nov 2, 2011 10:45 AM
montecarlocrazy
Oct 5, 2010 10:28 PM
wildnorth29
21
Sep 27, 2010 04:30 PM
vita
Mar 11, 2008 11:49 AM
Cowboy6622
Dec 15, 2007 10:40 AM
