engine swap questions.
You would want to swap it with the series 2 supercharged engine, so that you don't have to convert your TB and such.
You would need the Engine, trans, axles, PCM and engine harness from the donor.
I prefer it, because in 2003 they made a change to the transmission and the stock .bin file from an 04/05 supercharged Monte wouldn't make that connection, so you would have to have a custom .bin made.
theres a sticky thread on it from bumpin96monte,it gives a general idea,and im not %100 sure on the axle,i think you have to use half the 3.8 axle to bolt up to the transmission,then use your other stock half for the outer pieces,maybe someone will come in and clear it up,like I said im not %100 sure,but il be swapping in the next 2-3 months (if everything goes right) and il post a walk through for the 00-05 montes
