engine swap question
Old Apr 6, 2009 | 05:40 PM
allstar_jessica12's Avatar
Question engine swap question
have a 96 monte carlo, how do i pull the motor without losin my anti theft code because what i hear once you lose power youd have to go to a dealer to reinstall my code, is there anything else that i might lose, or any way around this? thanks...
Old Apr 6, 2009 | 06:52 PM
Hi New Member: AllStar_Jessica13,
Welcome to the Monte Carlo Family Forum
Please wait for one of our expert tech members to read your post
and advise. While you wait, you can read the below
SpeaceWebSearch finds: Good Luck
Check back 2 see if another member post infor.
<LI about="r12">
Auto Theft Prevention - Cars - Shopping - AllExperts.com
Q: was wondering if they make an anti theft light that you can mount somewhere ..... Q: I had to change the battery in my '99 Monte Carlo not realizing there is the ..... Q: Rob: I just purchased a 1996 Mercury Sable. It has a factory theft ... bought the car and the person who sold it to me had disconnected the . ...
en.allexperts.com/q/Auto-Theft-Prevention-2384/i... - 91k - Similar pages
http://en.allexperts.com/q/Auto-Theft-Prevention-2384/indexExp_17145.htm
<LI about="r13">
[PDF]A Product of ECM. All engines. Any model be used...
If you do not have one from a production TPI harness, they are available from Howell Engine ... degrees F. Whenever the battery power feed is disconnected, the computer ... Code 46 is the. Vehicle Anti-theft system and you must have a Cal-prom ... Only our Monte Carlo/El Camino MAF harness is designed to operate ...
www.howellefi.com/skin1/pages/US/install_tpi_harness.... - Similar pages
http://www.howellefi.com/skin1/pages/US/install_tpi_harness.pdf
<LI about="r14">
Wheels.ca - New Cars, Compare, Pricing, Specs, Expert Car Re...
If the fitting becomes disconnected while the vehicle is in motion, ... Rendezvous, Deville, Trailblazer, Impala, Monte Carlo, Venture, Envoy, Bravada, ... reducing the capability of the bag to protect the driver. .... Theft deterrent system & Passlock security system ... 4-wheel anti-lock braking system (ABS) ...
www.wheels.ca/newvehicles/profile/17739 - 174k - Similar pages
http://www.wheels.ca/newvehicles/profile/17739
<LI about="r15">
Testimonials - Car Thief Stoppers
A county police officer told me if I wanted to protect an Acura Integra, the only way to do ... It is also an anti theft device that everyone can afford! .... He's driving a 1996 Ford F-150, which is paid for and is basically the last thing and the ..... They disconnected the ignition switch and tried to jump it. ...
www.carthiefstoppers.com/Testimonials.html - 108k - Similar pages
http://www.carthiefstoppers.com/Testimonials.html
<LI about="r16">
Testimonials
It is also an anti theft device that everyone can afford! I personally know how great ... I have a kind of success anti-success story for you.... I have the 2002 Monte Carlo. ... I thought OnStar would protect me, that's what the dealer said anyway. ..... They disconnected the ignition switch and tried to jump it. ...
www.ravelcobrasil.com/testimonials.htm - 47k - Similar pages
http://www.ravelcobrasil.com/testimonials.htm
<LI about="r17">
[PDF]AviStart 3200
s Do not disconnect the battery if the vehicle has an anti-theft-coded radio. ... Many airbag systems will display a diagnostic code through their ..... all pre-1996 Dodge Dakota pickup trucks with 2.5 liter motors. This solution has one side ... s 2000 and newer Grand Prix, Lesabre, Monte Carlo, Lumina, Bonneville ...
www.guardianalarms.net/home_security_manuals/Avital/a... - Similar pages
http://www.guardianalarms.net/home_security_manuals/Avital/avital3200-install.pdf
<LI about="r18">
[PDF]2002 Chevrolet Monte Carlo Owner's Manual
2002 Chevrolet Monte Carlo. Owner’s Manual. Litho in U.S.A.. E. Copyright General Motors Corporation ...... If your vehicle has the optional content theft ...
www.montemill.com/Technical/Manuals/2002montecarlo.pdf - Similar pages
http://www.montemill.com/Technical/Manuals/2002montecarlo.pdf
<LI about="r19">
[PDF]Model 562T
Do not disconnect the battery if the vehicle has an anti-theft-coded radio. ..... all pre-1996 Dodge Dakota pickup trucks with 2.5 liter motors. This solution has one side ... 2000 and newer Grand Prix, Lesabre, Monte Carlo, Lumina, Bonneville .... Once the code is learned, the Valet/Program switch can be released. ...
www.directeddealers.com/manuals/ig/valet/N562T_07-05.pdf - Similar pages
http://www.directeddealers.com/manuals/ig/valet/N562T_07-05.pdf
<LI about="r20">
[PDF]N562T 6-03.qxd
Do not disconnect the battery if the vehicle has an anti-theft-coded radio. If equipped with an air bag, ... Many airbag systems will display a diagnostic code through their ..... all pre-1996 Dodge Dakota pickup trucks with 2.5 liter motors. ... 2000 and newer Grand Prix, Lesabre, Monte Carlo, Lumina, Bonneville ...
www.directed.com/guides/manuals/ig/valet/N562T_6-03.p... - Similar pages
http://www.directed.com/guides/manuals/ig/valet/N562T_6-03.pdf
<LI about="r21">
[PDF]Do You Really Need a VCI Number ?
The theft module connector should be disconnected, located at the base of the steering column, along with the .... corrosion inhibitors, to protect engine components. - anti-wear. - anti-foam ..... code if available). - Any additional VINs with the same condition .... Riviera, 1999 Chevrolet Lumina, Monte Carlo, ...
www.norcal-cobras.com/GTM/gm-tech-link/3_00_e.pdf - Similar pages
Old Apr 9, 2009 | 03:08 PM
montecarlo01ss's Avatar
i guess im confused on what anti-theft code your talking about, u should have an obd1 pcm which doesnt have a lot of security features enabled like the obd2 pcms. u should be perfectly fine pulling the engine and not having to go to the dealer to have them do a security relearn if thats what your talking about
Old Apr 10, 2009 | 07:14 AM
montecarlossfan's Avatar
You have an obd2 pcm, I believe you are talking about the radio anti theft code, there is a way to retrieve these codes before you pull the battery..I forgot the exact procedure..I will get back to ya in a bit.
ssmonte415
Sep 27, 2013 10:11 AM
NewFish97MCLS
Mar 5, 2012 11:02 PM
Staind413
Jul 2, 2011 12:27 AM
Doug
Sep 21, 2009 01:50 PM
retr0kickz
Jun 22, 2009 10:05 PM
