new guy with a engine swap question
Old Sep 26, 2013 | 08:36 AM
ssmonte415's Avatar
Default new guy with a engine swap question
i was doing some reading on the forum about my low oil pressure light im gonna change out the part today and see if is the problem if not i also read could be bad crankshaft n will need new engine. in worse case i have a 3.8l non supercharged if i do need a new engine could i swap in a supercharged engine without doin any extra stuff. basically can i drop in and go or do i need any computer stuff
Old Sep 26, 2013 | 08:46 AM
You would need a new PCM to go with a supercharged engine. You would also need to modify your wiring harness for 2 additional plugs.
Old Sep 27, 2013 | 10:11 AM
ssmonte415's Avatar
well i figured out my problem i got under the car and there were loose wires to the oil sending unit fixed then n no low oil pressure light. dodged a bullet on that i guess
stoneagemaxx
Jul 16, 2010 05:47 PM
dcard1869
Jun 15, 2010 09:02 PM
Super Strong SS
Mar 22, 2010 10:49 PM
KodiakSS
Mar 22, 2010 04:43 PM
2000_BLACK_SS
Sep 22, 2008 03:42 PM
