Engine Shake
Old Feb 21, 2012 | 05:58 PM
soccerdude021489's Avatar
Default Engine Shake
I did an intake manifold gasket replacement and have everything back together and had the engine started. I have two issues though. I have one wire near the alternator that I can't find the connection for and when the engine is running it causes the whole care to shake. Any thoughts on what might be the issue causing the shake?
Old Feb 21, 2012 | 10:51 PM
The wire by the alternator may not be for anything. some vehicles have a few wires that are for other models. A pic would be helpful. About the shaking, Are all the motor mounts back on and tight? Is the motor itself running smoothly? have you driven the car or just ran it in the garage?
Old Feb 21, 2012 | 11:42 PM
how bad of a shake is it?
does it run fine?
do you have any other information?
Old Feb 22, 2012 | 02:01 PM
The engine mounts were never loosened but I could always check them. I have just ran it in the garage. It has been a while since it has ran since I have had it pulled apart but I vaguely remember it doing this before and it would stop once the engine was warm. Also I don't think it runs smooth to start with.
mwjames
Aug 11, 2013 08:45 AM
MayoJ1
Jul 2, 2012 09:29 AM
pelco
May 19, 2012 03:36 PM
moonlitmagik
Nov 9, 2009 11:08 PM
White05LT
Aug 14, 2008 03:01 PM
