Traction Active?
Old Aug 13, 2013 | 06:30 PM
ecosta221's Avatar
Yes i used a timken hub. And yea ive had the trac active came out a couple times before but that was when the cars tires came spinning off the line and such. Now its grinding because the sensor is shorted. The codes are the same two codes.
Old Aug 13, 2013 | 06:33 PM
ecosta221's Avatar
One code was for excessive reading and the other was a short in the system i believe
Old Aug 19, 2013 | 03:43 AM
ecosta221's Avatar
Alright well i replaced both wheel harnesses and tge lf hub and it fixed the traction active problem (knock on wood)
Old Aug 19, 2013 | 05:32 AM
JC Colon's Avatar
Congrats, enjoy your Monte and Drive Safe!
Old Aug 23, 2013 | 09:03 AM
dbaldwin's Avatar
Originally Posted by 03SSLE
If a sensor 'detects' that a wheel is spinning (whether it is or not) then the 'trac active' light will come on. This is normal. It means the traction control system is regulating the amount of power to that wheel in an effort to prevent it from spinnng.
I have this. What do I need to replace? It only will do it very rarely when I first put it into gear. But I don't have a service traction soon light ever.
Old Aug 24, 2013 | 07:10 AM
ecosta221's Avatar
Most likely you have the same issue i did. Id say take it to an autozone or something to pinpoin exactly which wheel it is. Then change both the wheel hub and the harness as well. Itll save you time and the headache. Mine was the right front at first and i changed just the hub. Well that didnt fix it and after while i was changing the other hub and both harnesses the left front was bad as well so i was glad i changed all of it. So get the codes checked first
bonang
Mar 6, 2009 08:22 AM
BeachBumMike
Feb 9, 2008 08:14 AM
NTIMD8T
Oct 20, 2007 01:03 PM
RocknSS04
Feb 26, 2007 11:09 PM
SoCalSS
Nov 18, 2006 06:25 PM
