Removing Ball Joint/Control Arm
Old Apr 23, 2010 | 06:38 PM
l0gitech87's Avatar
Default Removing Ball Joint/Control Arm
Hey Everyone!
I am new to this forum, as this is the first post I make. I have a problem with my 2003 monte carlo ss. I am trying to replace the control arm bushings on my car but I cant seem to find the right tool to get the screws off of the control arm for the ball joints. I cannot take off the control arm without disassembling the ball joint first. I've bought a huge set of allen keys but nothing seems to fit. Has anyone done this kind of work before? If so, any advice would be greatly appreciated. Thank you.
George
Old May 3, 2010 | 01:03 PM
chauncedogg's Avatar
Ya, please help as I need to do the replacing myself. How much is all this costing you George? Are you replacing because of a knocking noise everytime your car shifts or what?
Old May 3, 2010 | 11:02 PM
sonin66's Avatar
i think theres a special tool called a ball joint seperator(again i think)
Old May 4, 2010 | 06:13 AM
monte07's Avatar
hold on real quick are you talking about seperating the frunt hub from the ball joint. or are you talking about removing the ball joint it self? the reason why i ask there is so many different things can be described on how you worded the post. if you allready removed the front hub asembly you would need to drill the studs that hold the ball joint on off there is no way to get them off then drill with small drill bit then go from there.
Old May 6, 2010 | 03:04 AM
86_MONTE_CARLO_CL's Avatar
you dont have to take the ball joint out of the control arm to replace the bushings i actually just today tore apart my front suspension off my monte carlo.... use a balljoint seperator it is the same thing as a tie rod seperator and you put it at the top of the boot for the balljoint and hit it with a 3lb sledge or a rubber mallet the just unbolt the control arm and the bushings are prolly pressed in so youll have to rent the tool from advanced auto unless you already have a press now your car is 17 years newer so i could be wrong but i think its basically the same
Old May 6, 2010 | 03:06 AM
oh yeah chauncedogg your knocking is prolly a bad motor mount or tranny mount causeing the motor to shift and bang when the tranny shifts
Old Aug 6, 2011 | 04:51 AM
oliver's Avatar
been trying to replace the ball joint on my car for days now, like you George I can't take off the bushings too, so I think I have to bring my car to the dealership.
Old Aug 6, 2011 | 11:11 AM
03.SS.montecarlo's Avatar
Default Check These Procedures.
BallJointReplacement-03-Monte-3.8L.pdf
LowerContolArmReplacement-03-Monte-3.8L.pdf
LowerContolArmBushingReplacement-03-Monte-3.8L.pdf
Originally Posted by l0gitech87
Hey Everyone!
George
John1980
Apr 30, 2015 08:01 AM
weizie
May 23, 2013 01:26 PM
Silver SLP
Oct 23, 2012 06:08 PM
jasonsmith
Jan 22, 2012 01:44 PM
mbalser1
Jun 11, 2010 10:37 PM
