CV joint or ball joint?
Old Oct 23, 2012 | 05:56 PM
Silver SLP's Avatar
Default CV joint or ball joint?
I have a popping noise coming from the left front of my car.
Mostly happens when going in reverse and turning to the left, will happen when turning while in drive too, over bumps, etc.
Bushings are okay, control arm is okay, no play in the wheel. Took it to a shop and no one can find the problem. I suggested a CV joint but they said it would be clicking when going straight too. There is no vibration in the steering wheel. I'm thinking its a ball joint.
Anyone have similar issue, ideas?
I also just replaced both front struts, springs and mounts.
Thanks!
Old Oct 23, 2012 | 06:05 PM
Are the fender braces tight if loose they will make a popping noise..
Old Oct 23, 2012 | 06:08 PM
Silver SLP's Avatar
Just checked, they are tight
John1980
Apr 30, 2015 08:01 AM
jasonsmith
Jan 22, 2012 01:44 PM
l0gitech87
Aug 6, 2011 11:11 AM
mbalser1
Jun 11, 2010 10:37 PM
Nathan
Nov 1, 2006 03:58 PM
