Torquing castle nut on ball joint
Old Jan 22, 2012 | 12:36 PM
jasonsmith's Avatar
Default Torquing castle nut on ball joint
I've got an 02 Monte. I'm replacing the front passenger side axle. I noticed the castle nut on the ball joint gets 15 ft/lbs. Though, the axle is in the way, so you can't get a socket or ratchet onto the castle nut. I had to use an open ended wrench to loosen the castle nut.
How do you torque the castle nut on the ball joint with the axle in the way?
Old Jan 22, 2012 | 12:37 PM
r u sure its foot lbs and not inch pounds?
Old Jan 22, 2012 | 12:43 PM
jasonsmith's Avatar
Actually it's 15 lb ft plus an additional 120 degrees.
Old Jan 22, 2012 | 12:47 PM
thanks Jason...any comment on how to get the correct torque on it?(tool, torque wrench) ext short socket etc..?
Old Jan 22, 2012 | 01:44 PM
jasonsmith's Avatar
That's the question I was asking in my opening post.
John1980
Apr 30, 2015 08:01 AM
MnteCrloSS47
Oct 19, 2013 02:39 PM
Silver SLP
Oct 23, 2012 06:08 PM
l0gitech87
Aug 6, 2011 11:11 AM
mbalser1
Jun 11, 2010 10:37 PM
