Racing your Monte Raced a guy in your ride? Had that Monte Carlo of yours on the timed track? Tell your story here.
5th Gen ('95-'99): 14.95 NA with no valve train mods.
Old Apr 10, 2013 | 08:21 PM
turbo monte's Avatar
nice numbers!! i would use manley valves over si valves when you do your heads.
Old Apr 11, 2013 | 06:32 AM
z34phoenix's Avatar
The heads are already done, valves and all. I know the manley valves are better, but i think they are heavier. As is the exhaust valves are about the same weight as the stock ones. the intake are a little lighter. The main issue people had with the Si Valves was with turbo builds where they would run heavy springs on them. I'm going to be using L76 springs which are quite tame. Hind sight is 20/20... If i were to buy valves again i would have gotten better ones. Also i never would have sold the 1.8 SLP rockers i had.
Old Mar 13, 2014 | 09:40 PM
ReadyChevy's Avatar
Default 5th Generation Monte Carlo Z34 N/A 3.8
Hello Phoenix
What was all done to your eñgine before the swap and your 1st run because I have a 1999 Monte Carlo Z34 w/NA 3800 series 2 engine and want to start building it up little by little
Old Mar 13, 2014 | 11:16 PM
l67ss's Avatar
^do a topswap. Just l67 swapped my 97 monte ls. Couldnt b happier
Old Mar 14, 2014 | 03:22 AM
z34phoenix's Avatar
From page one "with only the air intake - ported TB - HV3 - Speed Daddy Headers - Full exhaust, I put down a 14.95@91.47"
My car started life as a 96z34 with the 3.4L DOHC engine. When I swapped to the 3800, I installed it with headers, full exhaust, my fwi/cold air intake, and tuning via my DHP. By the time I took it to the track I got a HV3 for it. The result is the time above. Oh... Also in NA form via tuning I saw zero gain in running 89,91,93 vs 87 fuel. I tuned for both and neither would allow more timing. Save money and run 87 while NA on the l36
I also agree the topswap is the more effective way to go. More power for money and more room for upgrades later. Headers are a pain to install as the fire wall needs cut and then pounded in. But it's worth the effort. Also having your own tuner, preferably a DHP powertuner, I feel is a must. I have better then factory drivability and safety. Power deliver/ transition from boost to cruse is seamless. It shifts smooth when normal driving and locks hard when I get on it. Air fuel is darn near +- .1 afr and fuel trims average less then 1% variance. Because of my heavy foot and short trips to work my mpg suffers, but it's a blast. Getting he topswap dialed in this perfect has taken 3-4 months but utilized my almost 10 years of tuning these cars. With my current mods, cai, ported; tb,blower, intake, fully ported heads with SI valves, L76/G8 springs, headers, light weight pushrods, 3.29 geared trans, and tuning with wide band o2, the car put down a 13.91@99.8 mph in street trim full weight on a stock pulley!
I now have a VS cam ready to go in and will be picking up a MPS pulley system. The idea is to have two tunes. One daily driving with a stock 3.8 pulley and another with a smaller pulley like a 3.4 or 3.5. My mods with a cam prob would allow me I run a 3.3 or even 3.2 but I think I would need injectors and would rather run on the safe side of supporting mods. High compression and boost aren't normal friends.
drivernumber3
Aug 12, 2015 09:02 AM
02on20s
Dec 4, 2014 11:12 PM
Leprechaun93
Dec 1, 2014 05:09 AM
robh68chevy
23
Apr 28, 2009 10:45 PM
blink916
Mar 1, 2005 03:33 PM
