Separating tail lights
Old Jul 26, 2011 | 09:41 PM
SpinEm_90's Avatar
Default Separating tail lights
Alright guys I have a question. has anyone on here ever taken the lens off of the tail lights? My old one has a bad seal so I was trying to see how to take it apart without completely destroying it so I could seal it back up in case the one that is on the monte now gets ruined. Any help would be great! Thanks guys!
Wow I really need to stop watching TV when I post stuff lol I spelled separating wrong in the title! hahah! Oh geez
Old Jul 27, 2011 | 01:21 PM
Jester_20's Avatar
I did my headlights, so i could tell ya how to do it, but I have no idea if the taillights are sealed the same as the headlights. I'll take a gander tonight and let ya know if it'd be the same process.
Old Jul 27, 2011 | 10:35 PM
SpinEm_90's Avatar
The tail lights seem to have a harder seal or something. They're bizarre to me. idk wth I'm doing when it comes to this lol
Old Jul 28, 2011 | 08:02 AM
I don't know if this works with the glue used to hold the headlights/taillights together, but I know some of the old Palm Pilots (pre-dating Smart Phones), the shells were glued together (thus if the battery went dead, you hand to brake the glue bond).
I talked to a guy that serviced the Palm Pilots and he said to open those ones up, he gently used a heat gun and slowly and gently pried them open. That might be what you have to do in your situation. BUT, you will want to be careful what glue you use to reseal. Some dry with a yellowish tint. You need something that dries crystal clear and won't discolor in sunlight.
Old Jul 28, 2011 | 09:33 AM
Jester_20's Avatar
i checked out the tails on the 06 and they don't look like they are glued together like the headlights are. none-the-less if you're determined to do it, throw em in the oven at 200 for 2-3 minutes and gently start prying. Just don't let them get too hot too quickly, it'll start to bubble/separate the lense and if you look at it at a certain angle it'll look crappy.
Old Jul 28, 2011 | 10:40 AM
SpinEm_90's Avatar
Ahh okay thanks guys. I thought about using a heat gun to do it with but I wasn't sure if it would work as well. I'll probably try to do it soon
Old Jul 28, 2011 | 11:46 AM
Jester_20's Avatar
FYI--i'd stay away from the heat gun. I've used them before but never on something like this. They concentrate a lot of heat in front of the gun, so if the plastic (lens) expands, it'll expand much more in one spot than say on the other side of the housing. You may not have a problem using it, but if you use the oven method, it'll heat the whole thing evenly, and cool evenly as well. IMO--like i said, i've never used a heat gun on something like this before
good luck
rg9johns
Aug 22, 2014 10:46 PM
TKG2000
Nov 28, 2011 02:03 PM
01LS Goin Bad
Oct 28, 2011 12:48 AM
RickAKATed10
Jan 23, 2009 10:38 AM
