Help!! Rusting away a beautiful car!
Old 06-01-2011 | 08:25 PM
Cowboy6622's Avatar
Taz said I was absolutely right before I editted in that bit about the fiberglass... just don't want to tarnish Taz's reputation. I wanted to keep from posting again, but o'well.
  #32
Old 06-01-2011 | 08:33 PM
Oh, well in that case you suck. Just kidding.
Thanks for posting the alternative tips.
  #33
Old 06-02-2011 | 05:43 PM
mistiksky's Avatar
What exactly will i need. Time shouldnt be a problem i just want this rusting problem gone!
I need rust doctor paint and what else?
  #34
Old 06-04-2011 | 01:13 AM
Cowboy6622's Avatar
Well ,if you need something like a wire wheel on a drill to clean off the "excess" dirt on the rust. Treat it all well with the rust doctor and a brush. You'll need a cup to put the rust doctor in. You'll need fiberglass cloth.. two types, one type looks like it has a bunch of dots in it, another type has strands in it nad is white in color... that's what you want. You then need a quart of fiberglass resin, and it iwll come with hardener. You need a paint pan or something ot mix fiberglass resin is. Use another brush, brush where you're going to put the fiberglass, then have a precut piece of fiberglass cloth to shove it the place. Use a metal grinder, sand paper, something, to cut away the excess fiberglass. Use bondo and a spreader to smooth it out, sand it smooth, prime the area, and paint it. Since the area is in a fender well, I think you could honestly get away with going to CarQuest where you can actually get your paint code mixed in touch up paint.. and just paint it with a brush. I don't think it would be noticable to most people. If you do paint with a brush, do NOT use a thinner in the paint.. it will run all over the place if you do.
This might last a few weeks, might last a few years. I'd think ti would last at least 6 months to a year if you do did a really sorry job of it.... even so, the rust is treated, the only danger shoudl be the fiberglass and bondo popping out.
xxtheshockerxx
03-20-2013 12:23 PM
ckerdflag
06-26-2012 10:51 AM
Jomao_o
07-10-2009 08:36 PM
cain45
07-20-2007 07:46 PM
Quick Reply: Help!! Rusting away a beautiful car!
