Some people shouldn't work on cars...
Old Oct 21, 2013 | 03:31 PM
Red Nightmare's Avatar
Default Some people shouldn't work on cars...
As some of you know, I'm a parts manager at Autozone... I've seen and heard some crazy stuff at work but this has to take the cake...
I'm going through my nightly returns, and I pick up a box of brake pads that says "Damaged"... noticing the weight it felt like it had bran new pads in the box. I open it, and notice 2 of the 4 brakes were bran new. Then, the next two....
One of the prongs on the back of the pad was all bent out of shape..I'm thinking "Ok....i guess they had some trouble?"
Then I see the last pad. The braking surface was untouched, but then when you look on the other side it seems the dummy installed it backwards.
If you can tell...that other brake pad facing the friction material has a backing plate..
so this idiot drove with this until he ground off or drove off the backing shim...then proceeded to brake on the metal surface. How the hell do you not notice your installing it backwards?!
so yea...there is my silly input for the day.
Old Oct 21, 2013 | 06:34 PM
JC Colon's Avatar
Yeah that guy should have his tools Revoked and he should be sent back through, "Turning Your Flashlight ON: 101"!
Old Oct 21, 2013 | 06:46 PM
That is a pretty extreme or epic fail. Guy was probably screwing around on a phone when he shoulda been paying attention....
Old Oct 21, 2013 | 09:03 PM
Zen's Avatar
Zen
Sadly I see a lot of cars come in after some one did brakes an they can't figure out why they have a noise an it turns out that they put a pad in backwards.Or for another shop
Old Oct 22, 2013 | 12:05 AM
ohara's Avatar
it never ceases to amaze me the whole concept of common sense. What most people take for granted in the fact that when things are laid out there is generally only one way to put them back, if taken apart properly, but some people can screw up just about anything. It is like the connectors being different sizes so that you shouldn't be able to connect them wrong, but some people seem to take the resistance of something not being able to fit (as it is not supposed to fit that way) and see it as a challenge to "make it work"
Old Oct 22, 2013 | 10:06 AM
Hi `Jen,
I've made several mistakes working on cars
and have said to my mirror many times
Mistakes can cost Big $'s sometimes/many times
4>$ure
"Hard Lessons Learned"
Old Oct 22, 2013 | 10:45 AM
Mels SS's Avatar
The noise alone should of said dummy there a problem!!
Thaigga
Jul 23, 2013 12:37 PM
milrlyt
Oct 31, 2012 09:16 PM
Milhouse
Jul 27, 2011 09:22 AM
oh3monteSS
Mar 16, 2011 08:06 AM
gothkid
Jul 24, 2010 02:48 PM
