Check engine light
Old Nov 3, 2021 | 09:39 PM
05ssmontegirl's Avatar
Default Check engine light
05 supercharged ss monte Check engine light came on auto zone said it was code for bad gas cap. Replaced w/new cap was ok for couple weeks now back on they said says bad gas cap lol. Difference now is when I get out I smell a strong gas smell at front of car. Any ideas? I really don't want to waste $ on another gas cap, don't think that's the problem & never was. Disabled & strapped for cash. Car now parked,tags just expired and I know it won't pass inspection w CE light on.
Old Nov 3, 2021 | 09:58 PM
Onion39's Avatar
I battled this issue for a few years, changed everything regarding the EVAP system including the gas cap. If it smells like gas from the front of the car, check the EVAP Purge Valve Solenoid. When I went to remove the solenoid, the tubing that ran to it basically crumbled in my hands. I went ahead and replaced all the tubing and the solenoid. Easy 10 minute job.
Old Nov 4, 2021 | 03:15 AM
claydoh's Avatar
Also make sure you buy a GM gas cap, the ones at auto stores not the same!
Old Nov 4, 2021 | 07:57 AM
If you are smelling gas up front then it could also be the fuel pressure regulator this is the one that makes the Plenum explode, I am attaching a link for the google search I did so you can read about it there are alot of these that have happened maybe you can catch it before it happens.
https://www.google.com/search?q=gm+3...client=gws-wiz
tfunk002
Jan 3, 2017 10:13 AM
BethinIN
Sep 6, 2012 06:11 AM
peno67
May 14, 2011 09:48 PM
rogg5204
Sep 20, 2010 09:43 AM
Blazed SS
Jun 11, 2010 08:12 AM
