Check Engine light and the Gas Cap
Old Aug 30, 2012 | 09:37 AM
BethinIN's Avatar
Default Check Engine light and the Gas Cap
I've only had my car since February, and I've had this happen two times now.
My CHECK (engine) light came on, and I didn't know why. I DID check the gas cap (take off, put back on) but it didn't do anything. I was going to schedule an appt with my mechanic, and the light went off. Probably 5 days after the light came on. I chalked it up to the gas cap.
It happened again this week. It hasn't gone off yet. I think both times, I filled up on a Friday and then probably didn't drive the car all weekend (maybe moved it in the driveway but that's it), and then the light came on on a Monday.
Does this happen to anyone else? Is there a way to speed up the reset-process or whatever-you-want-to-call-it?
Old Aug 30, 2012 | 09:42 AM
You can buy a code scanner and reset the light.
It's probably a problem with the EVAP system, which could be one of many things. Including a little charcoal canister that vents your gas tank.
Old Aug 30, 2012 | 11:21 AM
aussiek2000's Avatar
I would still take it to get scanned. Most codes will be stored. A multitude of things can turn on the MIL.
Old Aug 30, 2012 | 02:42 PM
Could also be a sign that u have a loose or cracked low pressure line!(rubber)
Old Sep 5, 2012 | 01:03 PM
WannaMCSS's Avatar
ive had my MC since Nov and this has happened 3 or 4 times now.
check cap light comes on, tighten the cap and it goes off
then a day or so later the engine light came on
i bought a scanner checked it and it was code P0455: gas cap or evap issues
Bought a new GM cap and it still happened again after that.
to fix it, it says
With a p0455, the most common repair is to:
  • Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
  • Otherwise, replace the gas cap, and/or
  • Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
I'm starting to think i have a small leak or something
but your first plan of repair is to replace the cap. from my understanding they need replacing every so often.
Old Sep 6, 2012 | 06:11 AM
A leak anywhere in the evap system will cause that code. FWIW, vent solenoids fail 3x more often than gas caps.
Jmontross89
Mar 31, 2010 01:35 AM
Jmontross89
Mar 17, 2010 08:59 AM
RickCoMatic
Jan 17, 2008 08:27 AM
dogmanx
Jul 29, 2007 10:18 AM
heatherd
Sep 18, 2006 07:33 PM
