6th Gen ('00-'05): Wipers work, but intermittent stops in up position. New motor?
Old Jan 5, 2019 | 09:40 AM
straffin's Avatar
Default Wipers work, but intermittent stops in up position. New motor?
Subject pretty much says it all. I've worked with the wipers a bunch: removing and replacing wiper arms, new wiper linkage, etc. They're seated fine, respond fine, but when using the intermittent function, they stop in the up position.
Is this a wiper motor issue? Would like to go off of more than a hunch before I throw $100 at a re-manned replacement.
Old Jan 5, 2019 | 09:43 AM
straffin's Avatar
Hmm...thought that the controller was part of the motor, but it appears there's also a "Wiper Motor Pulse Board Module". Is that what I need?
Old Mar 30, 2019 | 02:06 PM
straffin's Avatar
So, the Pulse Board is *not* what I need. Just swapped the old one out for a new one and there's no change. Lo works fine, Hi works fine, Mist works (but pauses briefly in the full UP position before parking normally), but the Intermittent settings all pause with the wipers in the full UP position.
Anyone have any info on this? :-(
- John
Old Apr 16, 2020 | 03:11 PM
avendo's Avatar
i just changed my motor and doing the same thing.i think its that thing with the spring that sets them..im lost
Old Apr 16, 2020 | 06:50 PM
Glen01SS's Avatar
Turn signal switch?
Old Apr 17, 2020 | 05:10 AM
avendo's Avatar
it was fine before i took it apart and screwed up the timing..
brecker57
Aug 2, 2011 06:27 PM
rinkrat33
Oct 27, 2010 08:14 AM
SGTILO
May 18, 2010 12:46 AM
jarheadbobandmax
Feb 11, 2010 11:05 AM
rob559
Feb 22, 2007 11:13 PM
