wipers out of sync
Old Oct 26, 2010 | 11:30 PM
rinkrat33's Avatar
Default wipers out of sync
I noticed on my 2002 Monte that the wipers stop mid windshield when on the delayed setting. They work fine on high or low. Is this a bad wiper motor or some other problem? Any help appreciated.
Old Oct 27, 2010 | 06:00 AM
http://en.allexperts.com/q/Chevrolet...per-sync.htm#b
"Your problem is probably a bent tab on the motor bracket or a loose crank arm"
Check the infor in the above link to see if it helps.
Also check back to see what other members will post that had a same or similar problem with their wipers...Good Luck
Old Oct 27, 2010 | 08:14 AM
montejass's Avatar
On top of Dino's post I would take a look at the wiper motor pulse board module.
I had this issue with one of my other GM vehicles and this module was the fix.
rinkrat33
Oct 24, 2010 07:45 AM
NYGiantsfan
Jan 19, 2010 04:57 PM
alesiter
Apr 4, 2007 06:14 PM
rob559
Feb 22, 2007 11:13 PM
dsetter
Aug 18, 2006 02:22 PM
