7th Gen ('06-'07): Whistling noise when accelarating
Old Sep 10, 2014 | 01:00 PM
seanpeezy's Avatar
Default Whistling noise when accelarating
I am hearing a whistling noise when accelerating. I think it's a surpentine belt but I'm not sure. It only starts doing it when I have been driving for a while. Any suggestions?
Old Sep 10, 2014 | 01:29 PM
vikesfan's Avatar
Old Sep 10, 2014 | 01:34 PM
vikesfan's Avatar
sorry, i had to.
the belt does sound like a good place to start, but my experience is that its louder when it cold, not after it gets warm.
i would look more at one of the idler pulley's or tensioner pulley.
Old Sep 10, 2014 | 01:36 PM
jim1405's Avatar
Is your acceleration normal? My 2001 started whistling from back pressure when the catalytic converter was plugged and eventually the acceleration got really bad.
Old Sep 10, 2014 | 01:49 PM
Have you had any work on the car recently?
Old Sep 10, 2014 | 03:42 PM
seanpeezy's Avatar
Yea the acceleration is normal. And it doesn't do it everyday just every now and then
Old Sep 10, 2014 | 03:50 PM
vikesfan's Avatar
i would look at the pulley's as i mentioned above.
to test it, when its warmed up and actually doing it, stop the car, pull the belt(s) off, and rotate every pulley (except the crank). if it is the pulley, you will know which one it is pretty quick. for the tensioner, you will need a 3/8" socket wrench to remove the belt and to flex it back and forth after the belt is off.
if you hear no squeaks or whistles, then its something else.
Old Mar 21, 2021 | 10:22 AM
itspike1488's Avatar
so let’s talk about this a little. My 01 has picked up a whistle that sounds like it’s a vacuum leak it is mostly under load but I can make it do it in park. Also it started after I first put a/c on this year a couple of weeks ago although that may be coincidence. It is a California car if that matters. I can take cat out now as it is no longer a California car. Lol... I’ve changed egr, map sensor, multiple lines and fittings. I’ve stethoscoped the area to no avail. It’s not running real bad except at top end and shifts funny to me now. Seems to be getting worse too. You would think I could pick up the whistle with the scope but I can’t for some reason. Sounds like it’s on the back of the motor behind coil pack but I don’t know for sure. Baffled to say the least...
Old Mar 21, 2021 | 01:01 PM
I had a leak from the exhaust manifold that made a pretty loud whistle sound. Not ticking or puffing like any other manifold leak ive ever heard, only a whistle and only while accelerating.
Old Mar 21, 2021 | 01:06 PM
So I scoped the manifold where I thought it was coming from. This is a California car and I fear the cat is messed up I’m going to Jack her up today I hope I’m very busy.
fenster25
Nov 6, 2017 08:45 AM
Kel-Vo
Nov 13, 2015 04:40 PM
SanJoseSS
Feb 1, 2013 01:29 PM
dave countie jr
Feb 16, 2012 06:25 AM
bigblack3
Apr 1, 2009 01:26 PM
