what purpose does a throttle body spacer..
"A throttle body spacer will insulate your TB from the heat of the supercharger. Keeping your TB cool will help keep your intake temperatures down thus reducing KR and increasing HP potential."
Straight from ZZP's website.
It looks like a lot of different terminology is getting minced together...
Throttle Body Spacer - A throttle body spacer is designed to increase the capacity of the plenum. This theoretically increases the potetial for producing power.
Throttle Body Insulator - As the name implies, a throttle body insulator is designed to isolate the throttle body and reduce/prevent heat soak through radiant heat transfer.
Throttle Body Adaptor - A throttle body adaptor is a plate installed between the throttle body and plenum to provide an injection point for nitrous oxide, methane or water depending on application.
Hope that helps clear up some of the confusion...
The gains of a spacer would be pretty igsignificant for the price of it. Of course zzp is going to talk it up. If I could get $150 for a small piece of aluminum, I'd make it sound like it could change the world.
also remember this, if you space the tb out away from the engine then you push it closer and over the exhaust cross over which defeats the purpose of spending money on it IMO.
Mod Guide: ls4 engine mount, throttle body spacer.
inssanity21
FWD Tech Guides '95-'07
26
Jan 11, 2012 06:03 PM
