throttle body spacer
Old Feb 4, 2008 | 11:24 AM
3800monte's Avatar
Default throttle body spacer
does a theottle body spacer help or is it a waste
Old Feb 4, 2008 | 12:41 PM
88ss408's Avatar
Default RE: throttle body spacer
i never saw a 3800 but i know that on the 660 they are pretty useless!
Old Feb 4, 2008 | 12:46 PM
IMO its a waste unless you need a place to tap for nitrous.
It will keep the throttle body cooler, but when you consider that the tb is a short (maybe 6" long) and straight shot- air doesn't sit in there very long. I doubt you could measure a difference in hp on the dyno because the actual change in cylinder inlet temperatures probably won't change much at all. I think there is other stuff you could spend the ~$50 on.
Old Feb 4, 2008 | 09:12 PM
z34phoenix's Avatar
it wont do much... unless the design helps make a smoother transition from the TB to the intake manifold. besides isolating heat from the engine to the TB it also increase the volume of the intake manifold chamber... this adds a slight high RPM increase and throtle responce.
but the gain is very small and like said not even able to be seen on a dyno. it wont hurt but the money is better spent on another mod.
Old Feb 4, 2008 | 09:20 PM
hey- look at that slow monte [8D]-digiphx
nice to see you over here too
kinda wierd being on a monte forum where I'm not captain post *****
inssanity21
FWD Tech Guides '95-'07
26
Jan 11, 2012 06:03 PM
Frosty LS1
16
Aug 24, 2009 10:58 PM
MadelynsDaddy
Aug 10, 2007 12:24 PM
Bml97MC
Apr 1, 2007 03:12 AM
2000_BLACK_SS
15
Aug 29, 2006 02:20 PM
