6th Gen ('00-'05): What is this called and where can I order it?
Old May 18, 2018 | 01:46 PM
EvanLauer's Avatar
Default What is this called and where can I order it?
This part broke off while I was putting everything back together (had to replace a cracked head), and I need to find a new one. I haven't been able to find anything on the Autozone or Advance Autoparts sites. The left side connects to the Evap Purge Solenoid, and according to the chart I found, the right side where the hose broke goes to the throttle body.
Old May 18, 2018 | 01:56 PM
You can run any hose there instead.. As long as it doesnt get sucked together from vacuum and heat..
I used a hose from a bike pump for a while with mine..
Old May 18, 2018 | 02:03 PM
SuperchargedMonte's Avatar
Check eBay.
Old May 19, 2018 | 02:51 PM
If you want that exact piece, it's a salvage or dealer item. I had to replace mine, I think the dealer charged me about $20.
Old May 19, 2018 | 04:12 PM
WBody's Avatar
P/N 24506665; Dealer should have it in stock or get a quick turn around.
https://www.tonkinonlineparts.com/p/.../24506665.html
Old Jun 4, 2018 | 03:52 AM
xpage's Avatar
i had to go to a dealer, then they gave me a part that waasn't quite right, about 1" shorter tubing. however you can get tubing at any auto store, as my tubing broke though the ends were fine in my original set
john0420
Nov 26, 2018 06:02 PM
Linda Jones
Nov 1, 2018 01:15 PM
michelob
Jun 3, 2013 08:24 AM
zachary
Apr 17, 2011 05:44 PM
Squeegee
Oct 14, 2010 04:44 PM
