valve cover question
Old Mar 18, 2013 | 01:59 PM
raspberry619's Avatar
Question valve cover question
What the difference between tall valve covers and short valve covers??? I have a 350 in my 85 ss and would like to know what is better and why
Old Mar 18, 2013 | 04:18 PM
DixieMonteCarloDepot's Avatar
Tall valve covers allow for more rocker arm and valve train clearance. Some people like the look of them more as well.
Rob
Dixie monte carlo depot
Old Mar 18, 2013 | 11:04 PM
So which would be better
Old Mar 19, 2013 | 12:49 AM
turbo monte's Avatar
If your planning to mod the engine with head work etc get tall ones. If your planning on leaving it stock pick what you feel looks better.
Old Mar 19, 2013 | 01:25 AM
I want to get headers and change out the cams and etc sooner or later but I think imma just get some more short valbe covers for now to make it look alittle bit pretty
Old Apr 7, 2013 | 11:14 AM
MossyOakSilverado's Avatar
If your gonna buy a pair of aftermarket valve covers beware of thin stamped ones. The flanges warp and bend and leak. If your set on a different set to have before all your upgrades either go ahead and get the set you wanna have in the end or look for a good used set on craigslist, racing junk, swap meet, ect. itll save money and hassell
Old Apr 8, 2013 | 09:23 AM
Thanks ill remember that
Old Apr 8, 2013 | 10:00 AM
03SSLE's Avatar
If you don't have stud girdles (that require a taller valve cover for clearance) I would stick with the stock valve cover height. When the oil squirts from the end of the rocker it hits the underside of the cover and drips to lubricate the fulcrum point of the rocker. The taller covers don't allow for this and the result is excessive wear of the studs. I have seen more then one engine with tall valve covers (and stock valve train height) that this has happened to. Just something to keep in mind when it comes time to buy some covers...
Old Apr 9, 2013 | 08:33 AM
Ok cool imma just get some new short valve covera just to avoid all that thanks for all your help you guu
prez
Jun 6, 2009 11:41 AM
ChibiBlackSheep
Feb 9, 2009 06:57 PM
14
Aug 30, 2008 12:34 PM
Ca$$e
Jul 25, 2005 02:13 PM
adreed24
Feb 10, 2005 02:24 AM
