2003 SS Oil Leak from valve cover or head gasket
Old Jun 5, 2009 | 11:33 PM
prez's Avatar
Default 2003 SS Oil Leak from valve cover or head gasket
So I am trying to figure out which is leaking, my head gasket, or the valve covers. In the crevices on the top of the engine, there is standing oil, and the car was almost a quart low. I took it in for a recall and the dealer said the valve cover gaskets need replaced, but it appears the oil is coming from the head gasket as it is on both sides of the engine (or both valve cover gaskets are leaking)
Ideas? I was gonna degrease the whole engine then see if I can spot some fresh oil.
thanks
Old Jun 6, 2009 | 12:06 AM
sonin66's Avatar
thats a great way to find a leak. but your suppose to up like flour around the engine to pinpoint it
Old Jun 6, 2009 | 07:27 AM
head gasket would cause anti-freeze in the oil, no?
Old Jun 6, 2009 | 09:13 AM
prez's Avatar
hmmm good point, I bet it is the valve cover.
Old Jun 6, 2009 | 11:41 AM
dustpusher's Avatar
It could also be the upper or lower intake gasket or both.This is a common problem also.
New2MonteNY
Apr 25, 2017 01:59 PM
wkimes
May 4, 2015 10:30 AM
Cowboy6622
Dec 14, 2011 04:05 PM
MonteMan92
Sep 11, 2011 10:22 PM
70monte1
Jul 7, 2010 12:13 AM
