6th Gen ('00-'05): Turn signals go off at times.
Old Jul 22, 2013 | 11:59 AM
DE02Carlo's Avatar
Default Turn signals go off at times.
One of my old Monte's (2001 LS) which is now my Son's has an issue.
He is out of state at College so I can't take a look at it.
He is driving and the turn signals work then go off (not blinking or lighting up) then they start working again. I told him to try the hazard lights next they do not work but have not heard back from him yet.
Do these cars still have flashers? Any other ideas? I am hoping it is not the multi-function switch or BCM. It only has 35k original miles.
Thanks,
Old Jul 22, 2013 | 12:16 PM
2001 SS Starting and Turn Signal Problem - Monte Carlo Forum ...
<cite class="bc" style="color: rgb(0, 153, 51); font-size: 14px !important; font-style: normal;">montecarloforum.com › ... › General ForumsGeneral Tech</cite>‎
Oct 16, 2009 - 5 posts - 2 authors
... problems. The first was the turn signals stop working or don't activate once in awhile. I'm.... I have a 2001 Monte SS which recently is showing a couple problems. The first was the ...2000 Chevrolet Monte Carlo · My Garage.6th Generation: 2001 starting/bcm problems?
Aug 10, 2012
6th Generation: 2001 Monte Carlo ss turn signal ...
Jul 20, 2012
2004 Monte Carlo Turn Signal Switch Repair
Feb 14, 2010
More results from montecarloforum.com
Hi `Joe, sounds like it could be a bad hazard switch (About $50) ?
Please read previous posts on this topic ...Good Luck
Old Jul 22, 2013 | 12:34 PM
DE02Carlo's Avatar
Thanks Space!
I saw the one on the multifunction switch. I just emailed my Son with the Hazard switch info. I also gave him a link to the forum (trying to get him to join).
Old Jul 22, 2013 | 03:14 PM
Jomao_o's Avatar
Try swapping fuses first.
Old Jul 22, 2013 | 04:56 PM
I would also look into the fuses first... if he hit the hazard switch and that didn't work then Space is right, it is most likely the hazard switch.
Old Jul 22, 2013 | 05:17 PM
JC Colon's Avatar
Hi Joe, I have the same problem with my 02 SS. I know it's the Hazard switch for me cause when i tap it, the blinker works and I've already checked my fuses. The fuse is a good check. If the fuses are good then when the blinkers don't work try flicking the Hazard button with a finger. If the blinker comes on then the Hazard/Blinker switch/relay is bad.
I'm Glad you put up this thread and Space responded with a better price than I have found.
Space, were have you found the Blinker/Hazard switch assembly for $50. I've looked all over and keep getting referred back to the "Stealership" who wants $100 for it!
Old Jul 22, 2013 | 05:23 PM
DE02Carlo's Avatar
Thanks for all the info everyone! I will have him try the fuses and hazards first.
Old Jul 22, 2013 | 05:50 PM
ryanb213's Avatar
In both of my 6th gens, the hazard switch needed replaced.
monteriderLS
Apr 1, 2013 08:57 AM
01whitess
Feb 18, 2013 08:55 PM
widebody
Jun 12, 2010 11:08 AM
MELISSA
Aug 14, 2007 03:29 PM
InTheIROC
Jan 11, 2006 10:55 PM
